Go to primary content
Oracle® Retail Integration Bus Integration Gateway Services Guide
Release 16.0.21
E86937-01
Next
Contents
Title and Copyright Information
Send Us Your Comments
Preface
Audience
Documentation Accessibility
Customer Support
Improved Process for Oracle Retail Documentation Corrections
Oracle Retail Documentation on the Oracle Technology Network
Conventions
1
Introduction
Prerequisites
Prepare Oracle WebLogic 12.2.1.2 Server
Create the RIB IGS WebLogic 12.2.1.2 Managed Server
2
Install Integration Gateway Services
Run the IGS under RIB_HOME
Verify the IGS Application Installation Using the Administration Console
3
Customize Integration Gateway Services
Prerequisites
RSE and AG-Overview and Relationship
PL/SQL Provider
JavaEE Provider
Artifact Generator Inputs and Outputs
RSE Inputs and Outputs
Extend an Existing IGS Web Service Provider
Use Case Scenario
Approach
Artifact Generator Work
Prepare RSE
Deploy the Customized IGS
Test the Customized IGS
Add a New Service to IGS
Prepare RSE
4
IGS and Clustering (High Availability)
Thread Value
Routing Information
5
Secure Integration Gateway Services
